Ok so I have an 87 na shell which I'm swapping to a jdm 89 turbo engine. When I got the motor I noticed they had cut the wiring harness right behind the alternator where it goes to the fuse block, check connection ignitor and the two wire fancy little ground box. Well it took lots of wiring diagrams, dismantling of my 87 harness., and a few headaches but I figure out about 23 of the 26 wires they cut and I'm using the connectors from my 87 to fix it. Im only three wires away from finishing my swap can someone please help me? The threee I need are: grey with green tracer and red rings, green with black tracer and red rings and a blue with a white tracer with no rings. Ill post a pic if I get acess to a pc but I can't from my phone. Any help is appreciated.
