wiring diagrams
#1StunnaVic
228
Bronx
hey i found some diagrams on 1jz-gte.us on how to wire up the 1j in ma70 supras and i just wanted to know if anyone has used them and can they vouch for them that they are correct and accurate?? i searched but didn't find anything on them. thanks also i saw some wiring information on how to wire a soarer 1j into a ma70 on this forum and i wanted to kno if anyone can vouch for that one as well.
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
It might be hard to find soarer diagrams how to put that motor in a a70, since most people put supra motors in supras and soarer motors in sc300.
You can search soarercentral.com for jzz30 ECU pinouts, and the jdm z30 body pinouts are the same as the z31 american sc300. It's in any repair manual
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I can vouch for it. I posted it and used those instructions to do mine and it runs. But, that's entirely up to you though. Odomd spent countless hours doing the wiring to make sure it's right. Good luck
http://www.supramania.com/forums/showthread.php?t=43888
Ninja edit: Damnit, you beat me foreverpsycotic.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
im just a beast like that :biglaugh:
remember, even if you get a soarer 1j clip, you need to get a bellhousing and flywheel (either r154 from a 1jz or w58 from a 2jz, whatever you have) if you want to go manual, you will also need to swap the oil pans.
#1StunnaVic
228
Bronx
i havent bought the motor yet but i just wanted to kno in case i cant get a supra 1j and ended up with a soarer i wanted to kno that this works
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
wait what?? you can use the front sump oil pans with the soarer 1jz and the aristo 2jz? i thought they didnt clear the crossmember...
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
It is a rear sump. See....
