Wiring diagram O2 sensor
mk3_supra
141
vancouver
I hate to post a new thread on this but I can't find anything anywhere, checked search on SF and SM google,tsrm,ma70.com, I need a wiring diagram for the O2 sensor I'm replacing the stock one with a universal and am probably going to need to splice/butt connect the new one as the connector is no good.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,282
73
Atlanta
Well, I just finished mine, but my wires didn't exactly match the diagram.
I had red/green, yellow/black, and a double shielded brown wire(88' turbo).
Obviously, the brown wire is the signal wire, as it's shielded from RF, and I verified this by checking continuity to it through the diagnostic terminal.
You can tell it apart from the others, just by it's larger gauge, even if the colors are faded.
HTH.
mk3_supra
141
vancouver
HTH.
Thanks for the diagram/follow up. Did you go with a denso sensor? Took a look at mine this morning they don't match the diagram either I think that might be for 89+ on that site. So brown to signal and the other 2 don't need to be matched?
