Will this rim fit ?
JZA80RR
50
norway
i am gonna run slicks on the track with my mk3 supra,and got som rim's i want to buy,but will they fit ?
rim come from a mk4 and are: 8x17 with +40 offset
oem supra mk3 wheels are 7x16 with +37 offset
yokohama slick's are 240x610x17
woud the rim/tyre fit or will it rub?
te72
Classifieds Moderator
6,624
9
WHYoming
It'll fit for sure, but I'd look into a taller tire if I were buying slicks...
CT26smoker
223
Houston
Hope you have welded some reinforcements into your rear subframe.....
They break if abused with sticky slicks on a sticky drag strip.
JZA80RR
50
norway
i am not dragracing,just gonna use it on some open trackdays and run around the track :)
---------- Post added at 09:48 PM ---------- Previous post was at 09:45 PM ----------
i am buying used stcc "warm up" slicks cheap:) why woud you go for a taller tire ?
Is this for raid race or drag race. In drag racing you want a taller tire for mOre grip.
JZA80RR
50
norway
Archon;1687092 said:
stock front Mk4 rims is 17"x8" (50mm offset). I have use it on my Mk3 with 235\45\R17 tyres. No problem.
so your 17"x8" with 40mm offset - is no problem too
http://mkiv.supras.org.nz/specs.htm
ty thats what i wantet to hear :)
---------- Post added at 09:30 AM ---------- Previous post was at 09:28 AM ----------
i am not gonna dragrace :) but ty for the info
te72
6,624
9
WHYoming
I thought you were drag racing. Taller tire = more grip, higher mph per gear as well. Downside, they're a bit heavier, but if you have a good amount of power...
