Will these wheels fit my Supra?
juancc01
7MGTE
May 21, 2006
USA
do you guys know if this rims will fit into my 87 supra ?
the size is : 18x9 with a 5.95" backspace (+24mm offset) and 18x10 with a 6.4" backspace. The lug pattern is 5x4.5 (114.3mm).
tissimo
Stock is boring :(
Melbourne, FL
9 up front with a 24 offset will rub on the front.. as for the rear they'll fit fine.. I have a 18x10 with 35 offset and fits PERFECT!
juancc01
7MGTE
May 21, 2006
USA
what if i use spacers for the front wheels,
do you think tha'll fit the problem?
supra90turbo
shaeff is FTMFW!
MA, 01440
If you like them, buy them.
Remove one of the front struts with the car on jackstands.
Mount one of the front wheels to that side. Move the wheel up through the suspension travel. you will be able to see where it will come in contact. Put the strut back on and take it to a shop where they do fender rolling. Tell them where, and how it hits the fender and they should be able to roll the fender enough to clear.
