Will the Marling Crawler VSS sender work with an Autometer Digital Speedo Gauge?
empera
Authorized Vendor
Philly.
looking on replacing a speedo on my datsun running the w58 trans with a digital VSS sender and thought the only one that will fit is the MC VSS? Either way im a little confuse as the gauges are programmable but it doesnt say anything about working with a 4 pulse sender...only 16 but i then saw it can be programmed/calibrated to work with a 8 pulse? So it might be able to do the MC 4 pulse?
Any one here ever swap over to a digital sender? Or know for sure if this will work?
Please let me know if you can help.
Thanks!
Chambers
Now you know
Sep 9, 2007
981
Baltimore County, Maryland
Looking at the trouble shooting specs on the MC one, "The 0.8~1.2 V reading is the nominal voltage (outputs at least this much voltage at all times)"
The Autometer one says it needs to see 2.0-16v. Just by those numbers I'm skeptical that it would work.
