Will no radiator shroud cause a problem?
mikeoc1
109
Ft Benning
My 90 turbo came with a Godspeed radiator from a PO but no shroud on it. Should I put a fan shroud on it. It has the mounts for one, not sure if the mounts are for a supra though. Wondering if it matters.
8,900
It pulls air across the entire radiator, not just the fan part. And putting air on the engine has nothing to do with it.
te72
Classifieds Moderator
6,624
9
WHYoming
With these cars, any little bit of help you can give them to keep them running cool is worth your effort, so I would suggest running a shroud, *particularly* if you plan to drive anywhere with high ambient temps as Grimjack said. These days, even summer temps in cooler climates are getting warmer...
