Will A 87 Turbo 5 Speed Work On
boost-time
Ok fellas , I was wanting to know if a 87 turbo 5 speed bellhousing bolt up to a 1jz-gte ? I know I cant use a 7m-gte flywheel on a 1jz , but I need to know if the bellhousing will .
Thanks
SupraMario
I think it was the google
7
The Farm
more than likely no. 1jz and 2jz go together but the 7m stuff almost none of it goes with the jz's. for example the only way the r154 will mount to the 2jz is through the 1jz bellhousing. and if only the 1jz bellhousing mounts to the 2jz then the 1jz bellhousing prolly wont match up to the 7m. srry.
if im wrong someone correct me plz.
