why walbro?
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Get an MK4 pump if you don't want the noise. To me, my walbro isn't that loud. I can hear it outside the car better than I can hear it inside.
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
+1, my (2) in-tank walbros aren't that loud at all.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
I have a Walbro, haven't installed it.
I think the reason is that it's an easy install in the A7 chassis. The Mk4 pump is even easier, and is a better pump, but is more expensive. I got the Walbro, because at the time I got it, it seemed to be the tried and true solution. Not sure if I'll ever install it, or if I'll just get a Mk4 Denso pump.
destrux
1,183
10
PA
http://www.manta.com/c/mtgn3sk/high-flow-fuel-systems-inc
They probably are just china made knockoffs of a stock MKIV pump, because a company with 2 employees probably isn't making their own pumps. Maybe they aren't junk, but your guess is as good as mine.
I think the reason people use Walbro is because they're been around forever and never had any quality problems worth mentioning.
