Why me
natedog910
27
US
I set did the head gasket car ran good 4 about a month ..now after I washed the motor while running car is missing ,so I started to chance out plugs # 6 cyl full of coolant..what does a stock turbo boost to ,what do I torque down head to and am thinking about putting some block seal in system I don't want to take it back apart
Sent from my SM-N910T using Tapatalk
plaaya69
87T Supra
Nov 18, 2006
947
7
Lake County, IL
Did you have the block and cylinder head milled before you put the head gasket on? Also what head gasket and torque values are you running with?
I would not use that block seal as it clogs up heater cores and other cooling passage paths. It may be a quick temporary fix but not a long term.
natedog910
27
US
I took the head to a local machine shop ,did do anything with block but cleaned old gasket off..
SupraTrbo89
234
7
West Chester, PA
Was a stock head gasket used or metal? Metal should never be used without block prep as well as the head. What was it torqued to? How much boost are you running? Also, why would you wash the motor with it running?
If the head gasket is leaking it's coming off again. I would not use the gasket maker. It will eventually leak again and cause you more problems.
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
Stock boost is around 6.8lbs. You should torque head bolts to 72 ft/lbs for a stock application. Do not use any kind of block sealer. Just don't.
I'm having trouble understanding your post but after washing your engine it's missing? Then you took out the spark plugs and found coolant in the cylinder?
natedog910
27
US
Yeah that's what happen ,I don't think it's the head gasket I did a compression test on all cylinders that came back at
120 also pressurized cooling system and its holding not over heating. My quess a ignition coil or wires
natedog910
27
US
I can't explain the coolant in spark plug area .. and i should have noted this is not my car its my 17 year old sons car ... the only time i see it when there a problem..
plaaya69
87T Supra
Nov 18, 2006
947
7
Lake County, IL
natedog910
27
US
This not Wright car ran good for 2 months then I notice it started missing above 4 tho rpm so I pull wires off and notice coolant again...
plaaya69
87T Supra
Nov 18, 2006
947
7
Lake County, IL
Are the metal caps with the hex head in them leaking in the cylinder head? Other than that you have the small coolant lines that run through the throttle body and ISC valve and the rear heater hose that runs to the heater valve that could be leaking.
natedog910
27
US
Isn't those hex head bolts have oil running threw them not coolant?
plaaya69
87T Supra
Nov 18, 2006
947
7
Lake County, IL
The top 4 are for the oil and the bottom 3 (in between 1 and 2, 3 and 4, 5 and 6 sparkplugs) are coolant plugs.
7MA0-1A1
12
Tacoma
I had a similar problem on my GE motor in my old na i had. Hesitated and stumbled like what you described. You definently have a leak filling your plug gally. A 14mm allen socket will also help you tighten those allen bolts that hold on the gally gasket.
