Why is my radiator maintaining pressure for a long period of time?
Ya. You need to wait till the pressure bleeds off. Squeeze the rad hose first. Auto basics.
IndigoMKII
2,181
Madison, Virginia
What JJ is trying to say is, the coolant res is there for a reason. When the coolant gets low it creates a draw on the coolant res pulling and filling the coolant system as needed.
jetjock
creepy-ass cracka
9,439
Right. In a pressurized fully closed type system the radiator is always kept 100% filled by the reservoir. Therefore the tank is an extension of the coolant level. As long as everything is working there's simply no need for removing the cap. The less it's messed with the better.
Rollus
593
Paris, France
Sorry, english is not my native language.
If my understanding is good, the cap has 2 functions:
A check valve let coolant going from expansion tank to radiator under vaccum
A pressure valve (0,9bars or more for aftermarket cap) let coolant going back from radiator to expansion tank when radiator is under pressure.
If the pressure valve don't work, radiator (and the whole cooling system) remains under pressure. That's what I tried to tell by "if it doesn't open" in my previsous post
BTW, we don't know what is the pressure for BAM! coolant gushes out the cap...
Backlash2032
1,823
Nebraska
I think what he's trying to say is the cap won't let the coolant back into the radiator as it cools, but that would create a vacuum..
