Why I Picked Quick Extender Pro Over Phallosan Forte and Penimaster PRO
(After 9 Months of Real Use — My Honest Breakdown)Official site with 20% discount I used: https://geni.us/qep20
Hey all,
If you're like me, trying to choose a traction device that actually works and doesn’t waste your time, then this post might help. After weeks of digging through product pages, comparison charts, Reddit threads, and even YouTube reviews, I narrowed it down to three options:
- Quick Extender Pro — Rod-based, DSS technology
- Phallosan Forte — Vacuum bell + elastic belt
- Penimaster PRO — Modular vacuum chamber with belt/rod options
Why I Chose Quick Extender Pro (QEP)
1. Precise Tension Control
QEP is rod-based, which means you can set your traction levels in grams — up to 4000g in the Deluxe Limited Edition. That’s far more than Phallosan or Penimaster belts can offer. This allowed me to track my progress like a fitness plan.
2. DSS System (Double Strap Support)
This feature alone made QEP stand out. Instead of a noose or vacuum seal, you use two soft silicone straps that hold securely and distribute pressure evenly. No slippage. No pinching. No blisters. Just solid wear time every day.
3. Better for Long-Term Progress
I used QEP like a daily training routine:- Logged daily hours
- Increased tension monthly
- Adjusted rod length weekly
- Measured results every 30 days
4. Simplicity and Durability
No chambers to clean, no vacuum sleeves to replace, no air valves to break. QEP is steel rods, memory foam base, and silicone straps — easy to clean and maintain. After 9 months, it’s still solid.
5. Results I Could See
After 9 months:- +1.1 inches in stretched length
- +0.8 inches in flaccid length
- Noticeable improvement in girth and shape
- Zero side effects, thanks to good tension control and comfort pads
Comparison with Other Devices
Feature | Quick Extender Pro | Phallosan Forte | Penimaster PRO |
Traction System | Rod + DSS straps (4000g) | Elastic belt (~2800g max) | Vacuum chamber (modular) |
Wearability | Best seated/home use | Best for under clothes | Mixed (belt/rod/weights) |
Comfort System | Foam base + dual strap | Sleeve & bell | Diaphragm & suction cup |
Maintenance | Low | Medium (sleeves wear) | High (many parts) |
Curvature Correction | Yes (special edition) | Yes | Yes |
Price Range | $119–$349 | $379+ | $300–$400 |
If you need a device specifically for Peyronie’s, QEP also has a version for curvature correction:
https://geni.us/qep-peyronies
My Kit: Deluxe Limited Edition
This is the one I went with:- 4000g tension system
- Memory foam base
- Travel case
- Extra rods & silicone tubes
- Full set of gauze + spare parts
Final Verdict
Quick Extender Pro isn’t the flashiest. But it’s the most effective, stable, and customizable system I found. If you want something for real daily use, that builds up over time like resistance training, QEP is the clear winner.Whether you're focused on:
- Size improvement
- Confidence boost
- Curvature correction
- Post-op recovery
- Or just investing in yourself
Feel free to ask me anything about my routine, results, or how I measured my progress — happy to share.
