why did my wideband sensor Die!!
7m4runner
30
Atascadero
Does moister in the exhaust kill wideband o2 sensors
my engine started smoking bad...white exhaust, this is just after a profesional built head, milled and arp's after researching I discovered that the most probable cause is bad turbo seals...anyway my real question is that my wideband just went blank and no linger works, so did the moister in the exhaust ruin my wideband sensor?
AJ'S 88NA
2,419
Florida
It could if it is mounted wrong. Suppose to be mounted around 2 or 10 o'clock.
7m4runner
30
Atascadero
fixitman04;1358758 said:
coolant will kill one, but it has to be fogged pretty good. i have killed one before this way
It was smoking really bad, It comes and goes and only at idle, they say that a turbo seal, so I guess i will be needing a new turbo too :3d_frown:
