I just don't understand. No matter what I do to it, I just can't get a good idle...ever. It's always random misfire, Idle bouncing around bullshit. Its been like this as long as I've had it. Its on the second rebuild now. The IAC has been changed, coils, CPS, TPS, O2, AFM, coolant temp, and FPR.... and it still does this same bullshit. It will run smooth for a minute, and then you get a stumble, it goes rich for a second, and then smooth back out.
Mods are
Lex Afm, RC 5550's. NGK 3330's gapped at .026, AFPR, Walbro 255(hardwired 10 gauge, 12 volt mod), Ported Head, Wiseco pistons, Race prepped stock rods, full balance job, Cometic 2.0mm, ARP hardware, UR cam gears, Hardpipes, 62-1 Turbonetics turbo, NGK wires, Custom air intake, Greddy Emanage Blue with Additional injector harness, KS rewire, Electric Fans, Mr2 alternator, Optima Redtop, Ported exhaust manifold, BIC DDP, custom 3.5 inch exhaust, koyo radiator, 180 TRD thermostat, and some stickers under the hood.
WTF? I've got great, even compression numbers. 175 per cylinder. Leakdown came out 89/100 on all cylinders. I've got good engine grounds. Valves don't leak. Coil packs are within spec. CPS shaft is not loose, and air gap is correct.
Any ideas.... it just bugs me. I have always had this problem and dealt with it, but have never had a clue on the cause.
Mods are
