Why can't boost more than 9.5psi with a new T4?
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
Hi,
I change the CT26 for a T4, but I can't boost more than 9.5psi. :aigo:
I have a Digital boost controller Boost controller (AEM True boost controller) and I setup to 18psi but with out luck :cry:
Turbo Parts install it:
Wastegate:
50mm Valve
Die Cast Body, Billet Steel Valve, High Temp Silicone Diaphram
Capable of supporting up to 1000hp, 10.15 Psi Spring
In the top, don't have any bolt! is normal???????
TOYOTA 7MGTE STAINLESS " 321 " TURBO MANIFOLD
Presition Turbo T4, Hot side .68 A/R, Cool side .70 A/R
What do you suggest, I don't found any air leak, WHAT CAN I DO?:cry:
MKIIINA
Destroyer of Turbos
Plano, TX
check for leaks. how does boost build? you will need to change your boost controller to recognize that its and external vs. internal wg.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
Hey sorry I can't help but I just wanted to know what kind of FFIM you are running in your sig, does it retain ac? And btw tight video in sig as well. :)
OneJoeZee
Retired Post Whore
aboard the Argama
Yep. Me thinks you didn't switch the boost controller from internal to external.
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
Fletch124 said:
There is something wrong with your wastegate. There are usually 2 ports on an external gate, i believe you use the lower one.
Yep!,
My last setup:
I have the lower port to the boost controller.
the other ports unpluget.
The mornig test: 11.5 psi, but the boost controller is calibrated to 14 :cry: , so I have other wastegate, I will test for any leak, and also I will change the spring to 14.5psi. and see what happent.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Well from my experience with Tial wastegates you use the side port for a MBC or just connected to vacuum to run off the spring.If youre using an EBC it should be connected to the top port of the WG. But this isnt a Tial so what do i know..
