Who's running ms3 on a 1j?
destrux
1,183
10
PA
Check out the 1JZ fan page on facebook. There was a guy on there running MS and I'm 99% sure it was with a stock igniter. I think his name was Bob Moon.
Firing 2 coils at one time like wasted spark 1jz runs sequential ignition stock like the 2jz but runs batch injectors.
It is. But 1 and 2 only support 1 high current coil driver unless you mod it some how. Where as the ms3 supports 8 logic level coils. So you can have 8 smart coils and sequential ignition or have a ignitor driving 8 coil on plug in sequential.
IF you run your own harness you can do what ever you want but im going to make a pnp harness to plug into the factory 1jz harness. So i need everything to be able to work so i dont have to cut anything.
http://www.ms3efi.com/feature-xref.html
