Who put stock 2jz cams into the 1jz?
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
mabe if the fuel calculations were based on airflow, and not MAP vs. AIT vs. RPM. I'm assuming these runs were done at the same boost so I can't really see those changing. But who knows.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Ric said:
AF1JZ bought my 2JZGTE USDM cams.... I think he paid like $80 shipped or something lol
I think it was more like $50-60 shipped.
Can someone tell me the number difference in WHP in the dyno graph's that Joe posted? My server here at work blocks image hosting sites and I see red x's. I'm impatient and can't wait till I get home from work. Thanks.
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
17 more peak WHP. 300whp vs. 317whp.
Stock cams fall off the face of the earth at around 6500rpms and only made about 1000rpms of power over 300whp.
2JZGTE cams = Power all the way to 7300rpms, and 300+whp frpm 5500rpms to when he let off. That was over 2000rpms of over 300whp.
~300 HP on stock cams...~317 HP on the 2J cams. The good thing about the HP is the curve flattens out above 300 HP across 5500 rpm to redline. As usual on a 1J...very little torque gain ;)
Ric
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
For an argument, I dyno'd with stock cams and made over 300whp for 2krpms with the exhaust cam retarded 2.5 degrees with a crapload more torque.
OneJoeZee
Retired Post Whore
aboard the Argama
c_ronius said:
lol
aka MrsJohnson...sadly, he's back on SF. :cry:
Man, I thought something was all too familiar about that person's posts. It was too good to be true.
Ric, can't you be more creative and make a screenname that doesn't give away who you are?:stickpoke
odomd
computer illiterate
Jan 11, 2006
130
nj
Joos. I have my extra stock cams out. Why don't you bring over the 2j cams and we can then take them and my stock 1j cams to the machinist in burelington and have him cut em down? It could save you some cash.
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
Don't want to put down anyone, but I'm not really impressed by the 2jz cams numbers.
Here's a dyno I did 2 years ago on stock twins, stock cams, no cam gears.
Upgrades are: 550's, SAFC, A-VCR, 2.5" exhaust, Skyline IC
To translate: 'vermogen' = power in hp, 'koppel' = torque in Nm, the 438Nm equals 323ft-lbs.
So: 300+hp between 5000 - 6700rpm and 300hp up to 7000rpm...
(don't pay attention to the A/F's, they are from a probe in the exhaust which works crappy, we used the on-board AEM-uego and that was all good numbers)
Come on people, you can do better on 2jz cams!
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
So, what are you saying in your dyno :dunno: ? Was that a before and after with the 2jz cams? Or just your dyno numbers?
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
I'm saying these were 2 runs without 2jz cams, just the stock 1jz cams with some safc tuning in between.
So the numbers I've seen here on 2jz cams with stock twins are lower than this.
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
If you change to other cams, you always check the clearance after install. That will tell if you need to swap some shims here and there.
With a cam swap like this you can expect that you will need to swap a few out.
