Rich said:Yes, you're right about the hydro fan having regulated speed, but it doesn't move as much air when your engine is idling as two e-fans, the oil pressure is simply too low to generate enough power to spin the hydro fan fast.
No one over here is running the hydro fan, we all ditch it because e-fans simply flow much more air. When mine switch on, I can feel the hot air blowing under the car, throwing up quite some dust. The hydro fan does not do that.
And the stock thermo-switch IS suitable to switch the e-fans, I've been running mine for over 5 years without ever missing a beat and my temp gauge is allways rock solid in the middle, never goes up or down.
The relay, wiring and thermo-switch is reliable; it has been engineered to last.
I know your not using the stock temp gauge to talk about "rock solid" water temps. It has been proven time and again that the stock gauge will stay in the "middle" up to 110C ~ 115C and as low as 80C. That's a 30 degree difference.
