White smoke?
suprarich
Guest
Nov 9, 2005
2,187
ohio
What does it mean when white smoke comes out of my exhaust? I was racing my supra when it blew a radiator hose. Then I think the motor ate a bunch of fluid through the intake? Is this bad?
88YotaTurbo
658
Wolcott, Ct.
burning coolant. Keep an eye on it for a few days. It should clean up. Also I would suggest cleaning the whole engine bay (hosing it down and letting it dry). Ethynal Glycal (green coolant) is very corrosive and could cause havoc if left to sit on contacts.
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
I glanced at this thread and thought, wait a minute, isnt this the same guy always handing out advice on building 7ms? :biglaugh: :biglaugh:
suprarich
Guest
Nov 9, 2005
2,187
ohio
All kidding aside, I did blow my motor this weekend. I lost my coolent hose that runs along the block to the heater. Lost a bunch of fluid between the 1/8 mile and the 1000 foot mark. The turbo sucked up a bunch of it, and I do believe the pistons tried to compress a bit of coolent. So, long story short, my motor is hurt and will retire for the winter early.
suprarich
Guest
Nov 9, 2005
2,187
ohio
Yep, CP pistons, pauter rods, 9mm billet cams, head work, ferrera valve train, gt4294, th400, you know-- the usuall stuff.
