While trying to start my car up, after a couple of times of it trying to turn over, it puffed white smoke out of the intake at the throttle body. What does this mean?
BlackDynamite;913176 said:180 out of time......put it back on tdc and take out the distributor and put it in time according to the TSRM
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=IG&P=18
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=IG&P=19
mkIII213;913548 said:After aligning everything I took out the distributor and the timing was correct. Would something else be causing the engine to do that?
AJ'S 88NA;913569 said:How did you set the timing? With a timing light and the jumper wire?
Why did you pull the distrubutor?mkIII213;913678 said:I put the engine to TDC, pulled the distributor, and it was already correctly inlined. I did find a ground wire that was loose, but that shouldn't be the reason why the car isn't turning over and looks like puff the magic dragon every time it tries to turn over. It won't even turn over and start up in order for me to use the timing light on it. You get what I'm talking about?
AJ'S 88NA;913846 said:Why did you pull the distrubutor?
AJ'S 88NA;914011 said:Well I think now that he has pulled the distributor, he'll have to go back and set everything, cam gears, crank pulley, and rotor pointing to #1, then put a timing light on it. If all the above are lined up it should at least start as long as nothing else is wrong.
Have you checked the plugs, plug wires, coil wires, checked to see if you are getting spark?mkIII213;914409 said:Is there anything else that would cause this besides the timing?
AJ'S 88NA;914430 said:Have you checked the plugs, plug wires, coil wires, checked to see if you are getting spark?
mkIII213;914440 said:Wouldn't it be getting spark if the car fires like that and causes the white smoke?
AJ'S 88NA;914607 said:Well the only thing that I know of that will cause a backfire is timing, if you say everything is in line, and you have spark at the plug wires and the plugs are ok, the right ones and gapped right, your plug holes are free of water or oil, the plug wires are ok, I don't know what else to tell you.
Maybe cuel will chime in later with some more ideas.
BlackDynamite;915127 said:I'm also curious...;]
did you ever take out the cams, or take off the cam cogs? There is a alignment pin on each cam behind the screw and washer. It should be in the center hole on the cog. This could distort the timing(If i'm correct?) if it is not in the center one of the 3.
you can barely see them behind the washer in this pic.
