which mr2 alt'?>
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
i need to replace my alt the bearings fried during my bhg's and i wanted a smaller one, remebering the mr2 was a drop in (i think)
but i cant rmemeber the year i need to look for,
it's higher amp and smaller right?
thanks for any one that can help me,
i searched but mr2 altenator yeilded alot of threads bout ffi since they say altenator lowering bracket... lol
thanks again.
oscolivar1
Supraism
Feb 8, 2006
1,000
Virginia beach
100 amp MR2 alternator (1991 2.0L with powersteering). That year MR2 used an electric pump to run the powersteering. You have to change your pulley from the stock Supra alternator to the MR2 one...it's a tight fit, but bolts right up and the electrical connectors are identical.
if u have more Q'd that need to be answered Pm jdub as he has this setup.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
jesus, costless wanted 135 w/ core and 185 with out..
im going to shop around abit, i do have a few others so i can get ride of the bad noise but would be nice having more amps...
born2drv
1,199
Burbank, CA
that's the one i got.... and get it from autozone, lifetime warranty :)
also the 87-88 supra pulley will not work, and the pulley that comes with it won't work either... you have to use an 89+ pulley, i ended up ordering one from toyota.
MA717MGTE
boostaholic
Apr 2, 2005
404
Bristol VA
what's the difference in the alt pulleys between 86.5 - 88 & 89+?
ross1
188
va
pimptrizkit said:
score, shop press at school ftw~!
callin parts store!...
pimp, you don't need a press, just a wratchet, and maybe some longer hose to lenghten that hose that goes from the valve cover to the block, as it will be kinda crushed once the alternator is bolted in... atleast mine was, if someone has a way around that i'll take some advice?...
thanx,
ross
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
MA717MGTE said:
any one can confirm this? so if swaping to a pre 89, must use the 89+ pulley?
I'm pretty sure that's accurate. I recall a few members on SF had issues with the pulley (IIRC, one just had his machined to fit) while others had no probs swapping the pulleys.
