Which is rear KS? KNK1 or KNK2?
Shytheed Dumas
For Sale
Mar 6, 2006
967
Louisville, KY
I'm working on my knock sensor rewire and need a quick answer: On the ECU, is the KNK1 or KNK2 terminal for the rear knock sensor? Thanks.
supra90turbo
shaeff is FTMFW!
MA, 01440
IIRC KNK2 is the rear, but you really only need to know this if you're anal.
the outcome is the same regardless of which one reads a knock.
Shytheed Dumas
For Sale
Mar 6, 2006
967
Louisville, KY
Oops. I meant to post this in the tech section... Sorry.
Thanks Supra90.
One more question: Did should I punch a hole in the main harness gromet to pass throught the firewall?
supra90turbo
shaeff is FTMFW!
MA, 01440
I did, and I wouldn't recommend it.
Over time, the grommet tore like a 2" slit in it.
If at all possible, try to slide it through the existing hole. You should be able to do that, as it's pretty strechable. You'll need a buddy to hold the grommet open enough to slide the wires through.
