which clutch with 2JZ-GTE and R154 tranny
crazysupra2JZ
740
Georgia
i've been readin tons of archived threads bout 2jz swaps and i haven't been able to find out which clutch i should get when swapping in a 2JZ-GTE and using the 7M-GTE R154 transmission. i know i need the 1jz bellhousing so do i get a 7M clutch or a 2JZ clutch along with the 2JZ flywheel????
for now i want to keep the R154 until i can afford a new LSD diff, driveshaft and 6spd tranny. i'm not too mechanically inclined as to modigy shift linkages to make the V160 work. although i think i can bang the firewall a few times to get the stock twins to fit in
thanks
I have a 1jz and the clutches are the same for the 7m and the 1jz. I know absolutely nothing about the 2jz, but it seems like if it's a R-154 then the clutches would still be the same for them as well. Good luck.
crazysupra2JZ
740
Georgia
thanks, a guy on SF said i should get a 7M clutch cause it bolts to the 1JZ flywheel. so i'm guessing i need a 1JZ flywheel and 7M clutch kit then i'm all set?
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
that would be me AHAHAHAHA
Jay you are correct to use the R154 you need a 1J bellhousing and flywheel
so if you have a 1J flywheel whether it s on a 2J motor or 1J motor it needs the 1J/7M clutch kit
crazysupra2JZ
740
Georgia
great thanks for the double confirmation
Damn, for a second, I thought that said double penetration............I was leaving this thread...........:biglaugh:
I'm just playing so don't take nothing I say personal..........lol
crazysupra2JZ
740
Georgia
:naughty:
:naughty:
there are a lot of 2JZ's what come with ecu and engine harness only thing is that they're all auto....can i still use the harness and just get an aftermarket ecu?
The Reaper
Jan 10, 2006
1,909
Florida
yea right Jay you were HOPING it said double penetration you were thinking about it soo much it caused you to read it that way......
i wonder about you Jay
I'm too late, I came back on here to erase my post because it is postwhoring to the tenth power, but it won't do any good to erase it now, and Reaper, there's no need to worry about me. I'm as right as rain..............:biglaugh:
Mr. Crazy, I wish I knew more about what you're asking, but I don't. Some of our members have 2jz's and maybe they can help you out.........good luck.
