Listen guys ive done a little rebuild as one of my valve seats fell on to the vavle but to make a long storie short.. I did a compression test before the rebuild and it can back good as of one cylinder(5) at 96 but the rest are in the mid 120's... I resurfaced the head, checked the valves and put mineral oil on top of the pistons to see if the rings were bad they all held the oil..As i was near the end of the rebuild i decided to do a compression test and I only tested 4,5,6 and they all had mid 90's :1zhelp:
Could this be timing?? 180over... And i did put Cylinder num1 TDC on compression stroke before i started..I did have a metal head gasket at 75lbs without the copper spray.
I would like to get you guys opinnion on what this could be..
