Where to ground EBC.
Fubar231
402
columbus
Where should i ground my EBC that im about to install? Im going to use the 12v off the cig lighter for it, but wheres a good spot to ground it at up around the center console etc. If no one responds ill figure it out tomorrow when i go take stuff apart, but i'd be nice to know where a good location is.
airhead04
1,489
Lima, Ohio, United States
I believe there is a ground wire in the cig outlet too. Tap into that. If not find a bolt that goes to the chasis scratch the paint off and your golden.
Should be one in the radio also, tap into that.
Fubar231
402
columbus
Good shit man. Time to go look through cygnusx1. I don't think he has the radio schmatics/cig lighter wiring on there does he? Cig lighter maybe, but i doubt the radio. Do you know what color the ground wire is coming off the deck?
airhead04
1,489
Lol, wish I did. I started thinking about it, there is a ground wire in the cig outlet. I put my oil pressure gauge there, so I know there is one there. May be easier to get to that one. There are only like 4 wires behind it so its pretty simple.
Fubar231
402
columbus
I thought the only wire coming off of the cig lighter was the thick red 12v wire that slides over the back of it, but i may be wrong. Its been a few months since i had the center console apart.
airhead04
1,489
Nope, well atleast not on my 91. There should be 2 going to the cig and two that run off to a light for the ashtray light.
Self tapping screw would work also, just get the paint gone.
Fubar231
402
columbus
Oh man thank you a lot JJ! Thats exactly what i was looking for. Ill go ahead and print that out and take it out there with me tomorrow. Thanks again everyone!
Fubar231
402
columbus
Ok... I went downstairs to the garage to start to run the wiring, and i had a question. Would the ground wire coming off of the plug for the cig lighter etc. be a white wire with black dashs or something? Theres a 2 red wires, and 2 green wires, and a white and black one. I figured the w/b one would be the ground but im not entirely sure. Wanted to check here first. Anyways, gonna go run the vac lines for the solenoid then ill be back.
Thanks guys,
Shane
dumbo
1,913
Albera, Too Far North
If you have trouble reading schematics, you can also use a DMM and look for continuitity between a known ground, and the wire in question.
But yes the w/b would be the ground.
Fubar231
402
columbus
jetjock;1483121 said:
The comment made me laugh "RTFM", but i have NO clue how to read wiring diagrams like that.
I have a DMM but did not know you could test for "Ground" continuity with it. How would i do that?
Thanks for all the help guys! Making a last minute run to autozone for a vacume T thing and im done! Wish me luck!
Fubar231
402
columbus
airhead04;1483140 said:
Lol, a vaccum t thing. I told you there was a ground there.
Haha what else do i call them? There plastic T connectors for vacuum lines lol. Anyways, got it all working - that plastic T. Powered up, yadadada. Thanks a bunch guys!
