Where to ground at....?
PlatinumTracks
90
CA
I was wondering were yall ground your amps at...
I chose to ground it with a screw where the targa top goes but i keep running into issues every month or so and im tired of going back there to jiggle it...
any suggestions....
thesupragod
183
Mount Vernon, Ohio
i grounded mine to the battery, which happens to be located in the trunk. But i also ran a ground to the rear seatbelt bolt after cleaning the paint off the surface.
kicknsupra
147
PG BC
i grounded mine to the rear seat bracket
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
wherever you ground it, make sure to have a firm connection, and to use the same gauge wiring for the ground that you have going into the amp
pbasil1
Fully built 1JZ project
Jan 30, 2008
402
Huntsville,AL
The cross member at the rear seat is a great place to ground. Its thick metal and is in the center of the vehicle. Avoid using any pre existing bolts, always make a seperat ground on bare metal if you can. And use multiple screws if you must to make a good connection.
