Where to get a NEW OEM PS Pump?
I
itr206
Guest
Where can I get a NEW OEM powersteering pump. I lost my patience with this fucking think leaking. I have 2 that seem to leak from the same damn spot and I am annoyed now.
I heard something about a Lexus one working? Any one have any info?
I
itr206
Guest
I duno if they are the same.
Im trying to call Jeff Watson to see if he can get one, but I dunno if there is an alternate to use. I coulda sworn I saw some Lexus one will work.
I
itr206
Guest
I just called them , he needs to check with Japan and see if he can get them. He said they have reseal kits.
I am at a loss here. It seems to keep leaking from around the suction tube. I just put a new O ring in the other week and let the car sit and have a puddle again.
I wonder if somehow is something inside it is pushing fluid out the top?? I havent driven it to even put pressure on it. Othere then moving the wheel back and forth a few times to push some fluid to the pump from the canister.
I wonder how it would work with taking the suction tube off and putting some RTV or something in there to seal it better like a gasket or something.
I
itr206
Guest
I cant see exactly where its leaking. It just looks like its leaking from the top near the pickup tube.. I took that thing off last night and siliconed it up and put it back on and siliconed all around that gasket between the PS pump pieces and clamped the hose on tighter.
I guess we will see if that helps.
For the hose for that top port. It looks like its a real tight bend going into the pump. Is that normal? Anyone have pics of their pump and hoses from the can?
Trust_GTE
BOOST NOW...CRY LATER...
Apr 4, 2005
120
FL
I drove my car back from Cali w/ a leak in my PS pump...not fun! Anyways, I replaced all the hoses, did a complete flush, and sealed both end from the pump and resevoir. I'll take pics when I get home, btw I have an MK4 resevoir.
I
itr206
Guest
What exactly did you seal and with what?
I wonder if my resovoir is wacked too. Or mabye the hose from the resovoir to the pump is just too tight of a bend causing pressure to build up and leak.
Sometimes I can see fluid around the top of the canister too. So I wonder if its a pressure issue. Im not even driving the car thouh. So this is driving me nuts
I
itr206
Guest
fuck that. I dont wanna delete the PS> The cars steering reponse sucks in turns without it.
I
itr206
Guest
I have no problem driving without it. Ive done it in plenty of cars. I just dont like the steering response in this car without it. When you throw it into a wide turn with no PS is feels a little to jerky for me. I want this car to have the best of everything feeling.
I
itr206
Guest
JonnyRedline said:
mustang manual rack 4tw
Im not 1/2 assing my car. Even though its a 15yr old Poopra. I take my work seriously.
Point Is, I am fixing the PS at any cost. I will not settle for anything less
Ckanderson
2,644
The beach
mine is leaking fromexactly the same spot.. i belive it tobe my old hoses... just havent gotten around to ordering new hoses from champion
I
itr206
Guest
Are the hoses cracked? Mine dont look cracked.
Could be maybe the hose clips werent cutting it though. Im putting a like worm gear clamp on that fucker tonight and see what happens.
JonnyRedline
Lickalotapus
Sep 2, 2005
342
Supra's Interior
alright u need to relax buddy just take it easy we arent trying to hurt u here just chill you will get a new pump just neeed to relax just relax like woah
:love:
I
itr206
Guest
JonnyRedline said:
alright u need to relax buddy just take it easy we arent trying to hurt u here just chill you will get a new pump just neeed to relax just relax like woah :
Im just saying. I need info. not dumb remarks. I dont wanna delete it. You knew that already. I have good reasons for not doing what you mentioned and I stated that before already. I am looking for a fix.
I put the hose back on tonight with a real clamp and sealed the shit out of everything I can see with silicone and filled her back up and burped her. Hopefully this is the last time I have to do this.
