I have a 2jz-gte swapped mk3. I've been told my Rack and Pinion needs replacing. Does anybody know where and what kind of rack i should buy? I checked around and i can get a NA rack for cheap, but i'm not sure if i have to buy the turbo rack. Thanks
deazndude;1819071 said:should i buy one with or without a Variable Effort Steering?
bioskyline;1819080 said:generally if its a 89+ it should have the PPS option. it wasnt an option on 86.5-88 models.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=SR&P=76 <--- "presure contal valve" near the top of page. generally if the rack has that selanoid on the side of it, its PPS.
another image from a lexus, the supra is similar http://www.clublexus.com/forums/att...lug-drain-flush-bleed-system-diy-solenoid.jpg
