where does this plug go to???? car runs and die
vIetDrIfTeR
134
d town
where does this go to my car start for a second then dies
please help asap time is running out for me...thanksss
kHaNg
Like FAtHer Like SoN
Apr 17, 2007
177
Mass
take that alternator off you'll find where it goes
btw you have a turbo you shouldn't have posted here
just a reminder
SupraSabre
Older Then Most
Jan 17, 2007
62
Murrieta, CA
www.hamptonrpi.com
Not sure about a turbo, but on my NA, the Knock Sensor was disconnected (I couldn't find the plug until I removed the alternator) for quite sometime, the engine light would come on once I started moving, but the engine still ran.
vIetDrIfTeR
134
d town
no i dont have a turbo.didn't check any codes (no tool) it a MX83 stock just did head gasket. I disconnected the afm and it ran but died when i step on the gas. i start it again with the air flow meter sensor off and it ran, connected the afm and it died???? so it the afm im thinking.. right??? where is the knock sensor exactly??thankss
Devin LeBlanc
1,830
Las Vegas NV.
The car wont run without the AFM connected! Knock sensor is on the block, below the intake. Remove the alternator and you can get to it easy. You can still get to it without removing the alternator as well but its a little bit harder and have to know where it is. Its right next to the VSV mounted on top of the vacuum canister.
vIetDrIfTeR
134
d town
yesss it was the ks and afm was f up cause i pull it apart when i was doing a blown gasket bhg but it did ran when i disconnected the air flow meter, go try it but died when step on gas. thanks for the helpp
