Ok i hooked the ssqv up to a 20psi vacuum source and the valve does not open at all.
F Fletch124 2jz swapped! Jul 17, 2005 1,282 0 0 Reno, Nevada Sep 15, 2006 #21 Ok i hooked the ssqv up to a 20psi vacuum source and the valve does not open at all.
3p141592654 90T Oct 11, 2005 3,822 27 48 Thousand Oaks, CA Sep 15, 2006 #22 20psi? 20psi would be a positive pressure. Vacuum is not usually measured in PSI. You want in-Hg or Torr units.
F Fletch124 2jz swapped! Jul 17, 2005 1,282 0 0 Reno, Nevada Sep 15, 2006 #23 3p141592654 said: 20psi? 20psi would be a positive pressure. Vacuum is not usually measured in PSI. You want in-Hg or Torr units. Click to expand... yea yea thats what what i meant.
