where do these go?
OneJArpus
2,798
Get an aftermarket boost gauge it will show u how to hook it up. For the stock one to work i think you need the sensor off of the 7M but its useless and slow anyway.
For the oil perssure sensor to work you need the ss line made by Driftmotion.com and a 7M oil pressure sending sensor for it to work properly. The old sensor on the 1J that you have to remove is right above the oil pan on the driver side below the intake manifold. A PITA to get too.
the block thread is 1/8th BPT if you need to know and the 7M sensor is 1/8th NPT yes there is a difference between BPT & NPT and no you can NOT put the 7M sensor directly in the block as it is too big to even try
