Where can a source one of these reducers? *Pics*
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,250
Charleston, SC
I have a solid plastic 5"-3" reducer that works great for my 3" intake pipe to 5" filter. However, my new turbo has a 4" inlet and I'm trying to locate the same kind of reducer in the 5"-4" size. All I'm coming across are silicone reducers which will not work for me since the filters housing is silicone as well. The reducer needs to be solid.
Can anyone provide a company or link that sells such a reducer? I haven't even found the one I have anywhere, so I must be looking in the wrong places.
Thanks.
Mk3runner
2,033
Nor Cal
I've made along with many others intake setups from home depot. Kinda off sounding but it works.
MKiiiturbodrift
Cabot, AR
hey you can peice together a decent intercooler piping set in a hurry for cheap from home depot....lol. Of course its not the best way but when your factory pipe splits and you need a quick fix you cant beat it.
shaeff
Kurt is FTMFW x2!!!!
11
Around
Why not use a silicone reducer, then just use a small piece of metal or plastic piping to mate the silicone reducer to your filter. ;)
Mk3runner
2,033
Nor Cal
Soup can. No bs. Your local parts store shouldhave a spectre or somthing like it, it's a coated piece of plastic pipe meant for intakes. Could try that.
Or a exhaust connector works.. I'd go that route. Only 3 bucks for a 3 into 3 in coupling. Silicone reduce probably gonna be sitting near it to
