Wheel Fitment Q?
Status
Not open for further replies.
sai_supra1jz
Eat. Sleep. Boost.
Sep 12, 2008
171
CenCal, Ca
I just got some new 5-zigen FN01R-C staggered rims. Fronts are 17x8 and rears are 17x9, both with a +35 offset. I'm thinking about going 285/40 series in the back. Would there be any rubbing issues or any other problems. My rear is dropped about 1.75 inches. Thanks guys.
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
IMHO, a 265 or a 275 would be better suited to a 9" wide rim. Otherwise you'll probably deal with alot of side wall slop which will make your steering input less responsive.
sai_supra1jz
Eat. Sleep. Boost.
Sep 12, 2008
171
CenCal, Ca
If i go with the 275 then will there be any problems
2_TonedMKIII
Rarety
Jul 28, 2006
64
Orlando, Fl
Stock suspension? Or modified? If you'r running a modified suspension (ie coilovers) then you won't have any problem at all and shouldn't have to roll the fenders.
sai_supra1jz
Eat. Sleep. Boost.
Sep 12, 2008
171
CenCal, Ca
Right now it's on stock suspension, with the stock springs cut. Soon I'll be installing The Tokico struts with the Eibach Springs. Eibach springs have a slight drop only. 1.0 inches in the rear.
gtimportfanatic
Mk3 Addict
May 21, 2008
277
Hartford CT
if the springs are cut.. how u know its a 1.75 drop? .. lol.. aside from the fact that cut springs decrease the effectiveness of the spring.. ur ride height would by no means be perfect on these... i say do 275 for the rear and 235-245 for the front.. AFTER .. u get ur new suspension setup.. 275s should fit with that offset no problem
sai_supra1jz
Eat. Sleep. Boost.
Sep 12, 2008
171
CenCal, Ca
Well when i cut the stock springs to drop it, i measured a little over 1.5 inches and that's how i cut. So i estimated about 1.75 inches dropped. Right now I have my Work Mesh rims on 17x8 with 275 tires and it is still far from rubbing
shaeff
Kurt is FTMFW x2!!!!
11
Around
Cut springs are dangerous. That being said, we have an entire thread dedicated to wheel fitment, please post all wheel related questions in that thread.
http://www.supramania.com/forums/showthread.php?t=56843&page=21
Your question might even be covered already in there, check out the first page of the thread. I'm closing this one down. :) PM me if you have any problems with this.
Status
