wheel alignment settings??
queenskid926
Tires yeling @ every Lite
Jul 27, 2007
1,112
New York City
I brought my baby i today for an alignment since i never got one after i installed the eibach springs.
(* is for degrees just in case)
My original readings where:
Driver side front Caster 7.8*
Pass side front Caster 7.8*
Driver side front Camber -.7*
Pass side front Camber -1.4*
Driver side front Toe -.55
Pass side front Toe .25
Rear driver side Camber -1.2
Rear Pass side Camber -1.7
Rear toe .15*
The new alignment settings that they brought it too are the following.
Driver side front caster 8.2*
Pass Side front caster 8.1*
Driver and pass side toe 0.00
Driver side camber -.8*
Pass side camber -.8*
The rear remain the same for now because they where afraid of breaking the siezed bolts so I'm going back there tuesday with new ones from the dealer and they will adjust the rear.
My question is what should the above measurements be from the factory?
what is in spec?
