What's your current supra project?
spinningheadboy
Ich bin gegan alles
idaho
I'm at a standstill with my current suspension build(waiting for a new steering rack) and was wondering what MKIII projects you working on right now. Show me the pictures :)
I've added new tems struts, bump stops, full poly suspension bushings, including front subframe mounts, new end links, ball joints, and new goodyear trippletreads tires.
cwd
ValgeKotkas
2,224
Over the pond
Soon soon... rod knock repair and stuff, differential change, U-joint change, steering rack change, suspension spring change :D Oooh...it'll be niiice :)
balong
suprastar
Mar 17, 2007
197
Calgary
body work. need a front lip, lowering, and paint. woohoo
also just did my interior. just needa get a hub for my wheel
spinningheadboy
Ich bin gegan alles
idaho
MK3.0dudeman said:
why do you have all that wood over the motor?
That's an Idaho Cherry picker! :)
I'm dropping the complete front subframe and replacing it with a better unit.
The motor is held up by the subframe, so the motor needs something to hold it in place when I perform the swap, hence the firewood :)...and chain.
cwd
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
1jz-gte swap, MBC(in transit), tanabe exhaust, variety of driftmotion hoses and adapters, bic motormounts(in transit), electric fan conversion, jza70 lip fixing and install of said lip. aiming to get around 300 wheel with this AND be daily drivable while looking sexy
edit, forgot the MKIV na wheels and tires.
tissimo
Stock is boring :(
Melbourne, FL
current project.. finish assembling my 1.5jz.. fab piping, wire aristo harness up, pull the clutch out of my 2j and send it off to get fixed.. sell my 87.. paint my 2 91s
