Whats wrong w/ my engine [Video]
RPSil13
464
Anaheim, CA
So i recently had a code 41 vehicle speed sensor, because the speedometer cable came undone, i fixed that and now the engine is starting drive rough/stumble, the codes have been erased and the car driven around and no codes come up, i tried adjusting the tps to see if that would help but it didnt do anything
heres a video
can anyone help me out diagnose this :1zhelp::1zhelp::1zhelp:
i hope its not rodknock
thanks
Art
NTRA08
TWINKY
Jun 10, 2008
530
Conroe, Texas
I would get a timing light and see how your timing is. Sounds like you valves are tap tap tapping a little. should be 10deg btdc. at operating temp and idle. If it was a rod knock you would know it.
You'll love a valve adjustment. A lot adding and subtracting.
kamikazemkiii
1,219
North Carolina
X2
mkiiichip
1,434
WI
At toyota, an easy $600. If you do it yourself about $12 a shim + VC gaskets and grommets.
Not sure what these guys are hearing that would be ignition timing related...
whitemike
1,164
Winter Park, Florida, United States
heres a video
thanks
Art
Do you mean a code 42? Code 41 is TPS ..
RPSil13
464
Anaheim, CA
so i spent the day figuring this out, timing was perfect
the issue was my coilpack was not firing on the #4 cylinder, so its misfiring,
in the process of getting a replacement coilpack and will report back :)
