What's the ideal A/F vs boost curve look like?
born2drv
1,199
Burbank, CA
I'm thinking say:
16 AF @ idle / vaccuum
14 AF @ 0 boost
13.0 @ 5psi
12.5 @ 10psi
11.5 @ 15psi (assuming max boost at 15psi)
How do you figure out what is ideal? Is it good enough to vary based on psi or should you vary based on load/rpm instead? Some combination of the 2? Any help would be appreciated!
robbo185
693
Chicago
14.5-15 is good for idle/cruising
11.5-low 12's is good for wot
i base mine on just making the right curve for wot.....tune for the a/f ratio you want. 11.8 for me and i only tune 3000 rpm and above because ecu takes care of anything lower than 70% throttle and it will make it as close to 14.8 as possible
dbsupra90
toonar
indiucky
idle and cruise mid 14:1 is perfect. the ecu will do this for you in closed loop.
open loop off boost i usually shoot for mid 12:1 to 13:1. this is safe off boost and will help spool.
under boost i shoot for 11.5-11.8:1
i use this method whether its 5psi or 25psi, 100rwhp or 1,000rwhp.
Rajunz
Fast Coonass
Austin, Texas USA
I'm curious about this statement......................what would be considered open loop off boost
. I always thought it went into open loop under boost???
tissimo
Stock is boring :(
Melbourne, FL
I tuned 14.7-16 in low vac areas..
at 0 psi I go for 13.0-13.5
0-5 psi taper to 12.5
5-8 go 12.5 tapered to my target A/f under boost
8+ target a/f (11.3 on my personaly car.. i go concervative)
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
Yes, it does go into open loop while under boost, but ECU's kick out of closed loop control above a certian throttle point and a certian engine load. Typically this change over point is in the 5 to 8 in/hg vacuum range (75 to 85 kPa) and above usually 60 to 70% throttle.
dbsupra90
toonar
indiucky
thats funny. i didnt realize this was an old thread and started reading the responses. i saw mine and thought hey thats exactly how i do it! oh wait, that is me lol.
anyway, anytime you are at 75%+ throttle and not boosting i call off boost open loop. example- say im leaving a stoplight and 1500 i hammer down. from 1500-3200 rpm im not making boost (or just starting to) so i tune a little more lean.
