whats the gear ratio
JNasty
i drive fast cars (supra)
Jun 25, 2005
358
Jacksonville fl
i know that mine is a lsd and i know that an auto turbo is a 4.30 and i thought that na's were too as for the 3.73 i think that its a turbo 5 speed rear diff as well as a 3.90 but im not possitive
so what does the 4.11 come in
Ma70.Ent
1,871
NJ
You should have searched :D
http://www.supramania.com/forums/showthread.php?t=1084&highlight=gear+ratio
Or...copied from that link:
'92 Supra turbo automatic
Transmission: 4 speed AUTOMATIC
Gear ratios
1st: 2.80:1
2nd: 1.53:1
3rd: 1.00:1
4th: 0.70:1
5th: ???
Final drive ratio: 3.73:1
'89 Supra Turbo 5sp
Transmission: 5 speed MANUAL
Gear ratios
1st: 3.25:1
2nd:1.96:1
3rd: 1.31:1
4th: 1.00:1
5th: 0.75:1
'86.5 Supra NA 5sp
Gear ratios
1st: 3.29:1
2nd: 1.89:1
3rd: 1.28:1
4th: 1.00:1
5th: 0.78:1
Final drive ratio: 4.30:1
'87 Supra Turbo 5sp
Gear ratios
1st: 3.25:1
2nd:1.96:1
3rd: 1.31:1
4th: 1.00:1
5th: 0.75:1
Final drive ratio: 3.91:1
89-92 Supra Turbo 5sp (Stock)
Gear ratios
1st: 3.25:1
2nd:1.96:1
3rd: 1.31:1
4th: 1.00:1
5th: 0.75:1
89-92 Supra Turbo 5sp w/ OS Giken Cross Gear Set
Gear ratios
1st: 2.701:1
2nd:1.614:1
3rd: 1.215:1
4th: 1.00:1
5th: 0.75:1
All 89-92 turbo's had the same ratios. All 87-88 turbo's had the same ratios. All N/A's had the same ratios.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Holy shit... it is 4.30, that actually explains alot. Im used to domestics b4 this car, they are all high ass shit that doesnt pull at all, my firebird was 3.23 and NOT LSD (it was BS) and my old mustang, dont get me started....
JNasty
Jun 25, 2005
358
Jacksonville fl
i had an 89 and it was an auto , it had a 430 in it!!!the car was converted to a 5 speed. and i know that it had a 4.30 because me and john lunsford pulled it and tested it
MA70Supra88
Boostless
Boerne, TX
If you had a turbo auto with a 4.30 in it then it was not the original diff. N/A cars without the sport package did not have LSD (although I believe it was an option seperately some years). LSD was standard on turbo cars.
Jspec7m88
1,583
Nappy City
And slightly brushing off subject, but for you 5 speed fellers, It is an UPGRADE to get 4.30's (in your Turbo Model, of course;)) if you want a fast 1/4 mile car.
If anyone ever tells you that 4.30's are spin-city and can't hook up, smack them in the face. They obviously aren't smart enough to get sticky tires and such. 4.30's have shorter gears, which, inturn, would make your top-end a bit shorter, but as for acceleration, if you can shift well, will up your quarter mile times by as much as a second even.
:EDIT: Yeah, 4.30's don't come stock in AT Turbo's.
8,897
Gear ratios
1st: 2.80:1
2nd: 1.53:1
3rd: 1.00:1
4th: 0.70:1
5th: ???
'89 Supra Turbo 5sp
Gear ratios
1st: 3.25:1
2nd:1.96:1
3rd: 1.31:1
4th: 1.00:1
5th: 0.75:1
'86.5 Supra NA 5sp
Gear ratios
1st: 3.29:1
2nd: 1.89:1
3rd: 1.28:1
4th: 1.00:1
5th: 0.78:1
'87 Supra Turbo 5sp
Gear ratios
1st: 3.25:1
2nd:1.96:1
3rd: 1.31:1
4th: 1.00:1
5th: 0.75:1
Gear ratios
1st: 3.25:1
2nd:1.96:1
3rd: 1.31:1
4th: 1.00:1
5th: 0.75:1
Gear ratios
1st: 2.701:1
2nd:1.614:1
3rd: 1.215:1
4th: 1.00:1
5th: 0.75:1
His information is not debatable. This is what it is for US cars. All 7MGE's came stock with the 4.30.
The 7MGTE came with 3.91, and in 89 was switched to 3.73.
The transmission has no bearing on rear axle.
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
rule = n/a is 4.3
pre89 Turbo=3.91
89+turbo=3.73
na sport package (i think also an option) has the 4.3 lsd. All 3.91 and 3.73 were LSD
also the jza70 had a torsen lsd as opposed to clutch type... 4.11 i believe it was
