What's that clickin' noise?
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Also check the wiring to the two pins on the AFM harness closest to the headlight, they're part of the FC (emergency fuel cut) system for the fuel pump relay. If you've got a bad connection there or if the switch they connect to inside the AFM is shot the fuel pump relay will cut out..
CRE
Oct 24, 2005
3,485
Denver, CO
If the fuel relay was what kept clicking on and off and the new AFM fixed it, it was most likely the AFM's FC switch. ;)
