whats reccommened
mcammarn
matt
Feb 24, 2012
668
olympia wa
so this is whats done to my car as performance goes:
3in downpipe
3in test pipe
3in exhaust sytem
2 1/2in i/c pipe
i have a hks evc6 that i want to get installed and a hks turbo timer type 1.
i called a place that can do it (drift office in auburn wa), but they say its not recommended to install with just the mods i have.
so the question is, what do i need?
If your on stock turbo just install it and go to just under fuel cut.
A safc would be a good idea too.
Boost controller and turbo timer arnt hard to install either.
bioskyline
1,236
powell river bc
fuel system upgrades to use the higher boost are gonna be needed. around here on the pacific coast 10psi is pushing fuel cut, so 550's/lex is needed, and possibably a walbro or a USDM mk4 TT pump, with a adjustable FPR.
but what im wondering is why they didn't tell you that you need a fuel system upgrade?
or as hvy just sugested, install it and run at 10 psi?
mcammarn
matt
Feb 24, 2012
668
olympia wa
im not familiar how to even use the evc or the turbo timer. i mite have my buddy also do the install, as i dont want to do it.haha
i guess you can call me a noob with the aftermarket electronics.
not to sure what a safc is either.lol
and as far as as why they didnt tell me about fuel, not sure.im sure they just want my money.ha
but ill work on getting a lexus afm with injectors.
Turbo Habanero
4,229
Tucson,AZ
Everyone starts somewhere and yes electronics can be scary at times especially with a Pricey investment such as a car on the line
SAFC = Super Air Flow Converter
It is a piggy back system to the stock ECU it allows you to fine tune the Air/Fuel ratio for safety purposes so you can make more power
Sep 19, 2011
510
Des Moines, IA
Turbo Habanero;1819590 said:
I think the HKS evc6 is just a Electronic Boost controller
Thats all it is.
You better just do the usual mods first, like the 550's, lex afm, fuel pressure reg, and pump.
You can install those two items, as the turbo timer is always a good thing to have, but the boost controller is really not needed with a stock turbo, as they dont last too long under any more psi than about 12.
radiod
1,342
Abbotsford, BC
The list of AFM part numbers that will work:
22250-50010
22250-50011
22250-50030
22250-50031
They are from 90-94 LS-400 & 90-94 SC-400. If I remember correctly, the late 94's changed to a different AFM half way through and those will not work.
EDIT: Part number source - http://www.jblmk3.com/cars/lexus.php
