For a while ive been wanting to swap a 7mgte, but i recently started to consider the 2jzge as well. I was wondering which setup would be the least expensive in the long run.
I know for the 2jzge i can pick it up for a decent price, but i will need a 1jz bellhousing, 1jzflywheel, and bic motor mounts which adds to the initial price. Another thing that has me worried with the swap is the wiring. Since i was gonna keep it non turbo i could use my 7mge electronics and ecu? and what else would i possibly need to do this swap, ive read that many things hook right up but many were using the 7mgte harness. Also i would have to change the oil pan if i cant find one that is rear sump.
a few questions i have are: Do i need the harness from the 2jz in order to complete the swap? and what would be the most difficult part of this swap? One of the reasons i was considering the 2jzge is because i can always turbo it later down the road.
As for the 7mgte i feel it would be easier, but the headgasket job would add to the price, and i would have to get the turbo harness and ecu and any other little things needed for the swap.
Ps. In my car i have the r154, and turbo rear end. My power goals would be in the 300-400 range, but if i go 2jzge i would be fine keeping it n/a for a while
