What tranny would fit the 1jz?
andy_azn
19
can i use the 2jzge tranny on the on 1jz is the bell housing the same? i have a 1jz on my gs300 but i don't wan't to get a custom drive shaft i was thinking about using my 2jzgte tranny.some guy told me to use the 2jzgte tranny and i could use my gs drive shaft. can any one help me please.
Dew511
Q-boro, NY
GrandLordKhorne said:
Yes 1JZ and 2JZ bell housings are the same.
Wait a sec. The bell housings arent the same IIRC. The 1JZ mounts to the R154 tranny and the 2JZ mounts to the V160 tranny. They are totally different.
Somebody chime in and correct me if Im wrong.
drunk_medic
7Ms are for Cressidas
Woodstock, GA
I thought that the the V160 bellhousing [2JZ 6-Speed Getrag] was integrated with the tranny? It's bolt pattern where it mates to the engine is the same shape/bolt pattern as the 1JZ's R154 bellhousing. This is why the R154 can be used with a 2JZ.
The transmissions for a 1JZ to use would be:
R154 [5-speed manual]
W58 [5-speed manual]
A342 [4-speed auto]
A340E [4-speed auto]
V160 [6-speed manual]
These all bolt up, but of course you never know how easy or hard it would be to integrate the shifter and driveshaft - might have to modify these items on different cars/applications.
OneJoeZee
Retired Post Whore
aboard the Argama
POST PICS OF YOUR CAR!
drunk_medic
Woodstock, GA
supradan22 said:
Damn 1js are going into everything these days.
I believe the GS is the Aristo in Japan, which comes with a 2JZ. Mounting a 1JZ should be no problem, but I don't understand why he didn't just get an Aristo front clip.
andy_azn
19
i got the whole swap of the 1jz for $1,000. that was cheaper than the 2jz. the gs is the aristo in japan.
UkiSash
no mor sup :(
Jul 12, 2005
159
Weth CT
Im shure this has been said already, but itd be chaper to get a 1jz bellhousing and bolt it up to an R154 MKIII turbo tranny, still as good and about 75% cheaper than the V160. Thouse things cost a fortune.
