what the problem here
bis_1315m
197
charlotte north carolina
Alright so to make a long story short I'll start with my mods.
60-1ct, f-con, fcd, fmic, 2.5in piping, intake, hks bov, 10lbs of boost, walbro 255, 12volt mod to pump.
Alright I dont have a wideband yet but I have that gay bouncing afr guage.
and basically whats happening is my car is running super lean the light will bounce inbetween the red and the yellow as I drive at a steady rate and occasionaly go close to green without me changing my speed or anything and when I let off my bov vents to the atmoshpere so it goes really rich for a sec.
and back to red and yellow and when I boost it wont climb up to the green until I've reached full boost and it will be really rich.
The symptoms it's been giving me is it will bog occasionaly pretty often actual, everytime I drive it atleast and when it does bog I see my afr guage go to straight red and I feel a sudden loss of power but it will only do for a second sometimes longer than others.
I've replaced my afm and isc and I've even cleaned my fuel tank.
Mabye my fuel pressure regulator has gone bad or the fuel dampaner mabye or would it be showing others signs.
My guess is it has something to do with the fuel somewhere along the line.
So please help I dont want my motor to blow due to lack of fuel.
Thanks
Michael
and sorry for such a long thread
airhead04
1,489
Lima, Ohio, United States
Well Im not sure on how to fix your problem, but I do have a suggestion. Stop driving your car if its running lean or pig rich. You will for sure hurt something if you continue to drive it like that. May not be noticable at first but later on itll bite you in the ass.
Just my .02
Sorry I cant really give you advice on how to fix it.
bis_1315m
197
Failure14;1441252 said:
Does anything abnormal happen when your boosting? other than the AFR's
other then it running lean when I'm boosting it will bog as I'm hitting full boost it will bog constantly but even when I'm driving normally with no boost it will bog occasionally.
bis_1315m
197
I'm so confused right now I dont understand why my car would run pretty rich at boost and not at regular driving I understand the extra fuel is for the extra boost I'm pushing through it but why would it not give the car enough gas at normal driving just doesnt make any sense to me.
Anyone think it could be a fualty FPR or something of that nature
89supra7mgte
797
colorado
FRP could be an issue you could always jack the car up have someone in it to mock drive it, probably not too safe and actually monitor your fpr? does it smokes or anything? You could have an issue with your afr, giving you false readings? I would start with the basics get the correct actual fuel pressure and go from there see if there is a fueling issue, under boost or load your pressure should rise. Have you checked codes?
bis_1315m
197
Yeah I dont have any codes and I only have the stock fpr thats on the fuel rail right now and yeah I've been planning on testing the fuel pressure but man 50bucks for a fuel pressure tester sucks.
Do you know anyone that allows you to rent them out or something.
thanks.
figgie
Twin Cities, Minnesot-ah
bis_1315m;1441608 said:
I understand its a piece of shit but still it does tell me something.
And I'm not liking what its saying.
why not?
it is correct!
During cruise the car will teeter on the lean side and the richen up for a bit. Reason, to get rid of the NOx build up in the cat.
On boost, the car will richen up as per your description. also that vented BOV, you need to recirculate it.
bis_1315m
197
figgie;1441612 said:
why not?
it is correct!
Well my probem is that it doesnt richin up at all unless under boost and the car occasionally bogs and when it does bog I see it on the afr it will go super lean and I feel a loss of power and then it will go back between the red and and yellow once again and the power returns.
thats why I'm not liking it.
bis_1315m
197
Poodles;1441649 said:
The point is, you don't know that it's "super lean" as it's a narrowband.
true I see your point thinkin about getting a aem wideband do you have any experience with these I've heard theyre pretty good.
thanks for the help though
Ohh and any ideas of what the bogging could be coming from
bis_1315m
197
Poodles;1441654 said:
Could be any number of things, have you checked for codes?
Yeah no codes and no boost leaks but one thing I did notice when I did my boost leak test is that air was coming out of my dipstick does that mean my piston rings are shot or what and is there anything I can do about without tearing it apart.
thanks
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
And how is this going to give him any idea how the car is going to run when its under load?
OP: as others have said, get wideband!
thanks
Compression/leakdown test will tell you what's up.
