what the hell
supratoyota18
103
maryland
ok i just put my tranny in and i was driveind my car and it was runing ok. well i let it sit for a half hour and and went to drive it well it rans but was laggy
then i get to my freinds and turn it off and go back to start it and back out every time i hit the gas it would bog down then when u floor it. it starts to pop or die?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
doublecheck what you changed. did you throw an n/a trans in a turbo engine? maybe its a preexisting problem... sound like afm/isc(or whatever its called) probs
radiod
1,342
Abbotsford, BC
Engine warm/cool (do you have an actual temp)? Does it bog only under heavy load (ie, low rpm in higher gear) or all the time? Bogging at any rpm or just low rpm? Need a bit more info still on this one.
supratoyota18
103
maryland
fixed it i had my oil cooler on my rad so i moved it to right behind the driver side fog light. now the temp it good. thanks for everyones help
