suprarich;966532 said:Redline - anything else is just nut sack grease. I have 5 cases in my garage and it goes in everthing right down to my lawn mower. I would cook with it if it did not taste so bad.
jdub;966488 said:Not to mention your gas mileage
That's what kills me about the Eneos claim that using their 5W-50 increases HP...it defys the principles of fluid dynamics.
87mgte;966549 said:The type of oil you use can noticeably mess up your fuel consumption?!:runaway:
Damnit, jdub, you need to write a book.
quake;966582 said:i'm running royal purple 20w-50 but then again i built the motor for it and i drive it hard as hell. As for mileage if you want that buy a kia:biglaugh:
Doward;966661 said:You'll be happy to know that I plan on doing a virgin OA, followed by a UOA of the initial break-in oil (20 minutes run-time), followed by another virgin OA-UOA of the ring-seating (500 miles) then maintaining a UOA of the Redline oil for as long as I have the car. I anticipate 10-12k mile oil changes (as I will be running a bypass filter as well)
I think it'll be an interesting thing to see - a freshly build 7M, how much metal wear there truly is in the break-in period, and see how long it takes the engine to 'stabilize' into normal wear.
Honestly, I hope to find that after 20k miles or so, I have practically zero wear.![]()
jdub;966561 said:Yep and here's an article from a couple years ago about Toyota promoting the use of lighter weight oils to help improve gas mileage in the Asian market:
Lube Report Article
It's interesting that it alludes to the difficulty of changing the mind set that lighter oils are a better alternative since nearly everyone is used to using the thicker oils. That is exactly what you see here in the states as well among many mechanics and automotive "experts". It is happening, Toyota released a Service Bulletin covering a large number of their engines authorizing the use of 0W and 5W-20 oils to cover warranty requirements. Here it is...note the JZ series engine is one of them for using 5W-20:
mkIIIman089;966663 said:BTW - When do I get my SM Oil Expert badge?![]()
