What suspension parts have you guys bought and from where?
Before my computer crashed, I had a page saved that had a few parts in the rear of our cars in a kit for sale for about seven hundred dollars. I can't find it now. I do a little street racing and a little drag racing. I want to replace a few parts like the traction control arm, tie rod ends etc. What have you guys bought that helps the car in handling and basically just replaces 30 year old parts. I occasionally drive over the speed limit (way over) and would like to know my car isn't going to wreck due to faulty, worn out, rusty, or just broke parts. Should I just replace with OEM or go with newer technology and maybe stronger parts. Thanks, Jay
driftmotion, rhd japan, suprastore, thm motorsports.
There was a kit with a full set of aftermarket parts for the rear of the MKIII for 700.00
Either way, I've bought a few things from driftmotion. I'll start replacing everything a little bit at a time. Thanks.
Are you talking about a lsd rebuild kit or parts that go under the rear of the MKIII.
Here is a start for the parts http://www.driftmotion.com/category-s/1831.htm
If you're looking for lsd parts. You can get them on driftmotion also. I bought a newly built lsd from Piratetip here on supramania. It wasn't cheap though.
This is what I've ordered so far:
1 of : Battle Version Camber Links for MK3 Supra
Processing
1 of : Battle Version MK3 Supra Front Swaybar Adjustable End Links
Processing
1 of : Battle Version MK3 Supra Rear Swaybar Adjustable End Links
Processing
1 of : Battle Version MK3 Supra Rear Traction Links
Processing
View Order
seoul4korea
620
San Diego, CA
www.supraforums.com
I have all battle version pieces for the front and rear, Ronnie K subframe bushings for the rear, Poly bushings for everything else, ST Suspension sway bars, and new OEM lower ball joints. The only thing I didn't do was get the Beech upper control arms... because well... those are hella expensive lol.
My first batch from Driftmotion is suppose to be here early next week. I will install them and then make another order. I want this thing to be fast.........and ride better than most 26 year old cars.
