What should I do?
Justin
Speakers?
Spokane, Wa
Yes, this is a cross post from supra-forums but each forum has their share of experts....
I got a JDM engine from a shop, pulled it apart and am taking the head/crank/block/pistsons, yada yada down to the machien shop tomorrow to get some stuff done. what I'm planning on doing as of now is......
turn crank
hone cyl. walls
hot tank head/block
paint block
replace all bearings
prep for MHG
and possiably shot peen the rods.
Any suggestions of what I should do?
www.bouscal.net/engine/ <--- pictures I thought would help with suggestions... all are over a 1MB, 56k be carefull
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Well, we'd likely have a lot more in the way of suggestions if we knew what you were going to do with the engine after you put it together. There is a very different procedure for someone building a 1200 hp drag car vs. someone building a stock car.
