What Sensors Are These?
YouGotSpooled
290
Saskatoon, Sk. Canada
Hey guys. Just going through my wiring harness and tidying a few things up. Which sensors are these? They both are 3 wire sensors and from my knowledge the one on the right is the MAP sensor correct? If so I am missing the wiring/connector for it. How would I go about wiring this back up in my harness? Which ECU pinouts should this sensor be connected to? Any help would be appreciated and I hate wiring but would like to get my car up and running soon! Thanks!
seoul4korea
620
San Diego, CA
www.supraforums.com
The one on the right is your map and then left is the sensor for your boost gauge I think. Is this a fresh swap? As in is everything in the car already? You can search for the ecu pin out and then trace those wires back.
Backlash2032
1,823
Nebraska
The one on the left will say what it is. The one on the right is for your boost gauge.
Sent from my HTC6435LVW using Tapatalk 2
Backlash2032
1,823
Nebraska
I just noticed this was the jz section. The sensor on the right looks like the boost gauge sensor for a 7M. And I don't know why Toyota would use anything else on a JZ
