what motor?
bighroder
big guy in a little car
Nov 15, 2007
11
Michigan
sorry these questions might be a little dumb but I realy dont know much about toyotas in general. just a couple questions about motors.
what motor did a mkIII supra TT have?
what is a 1.5JZ?
and would putting a metal head gasket fix the bhg problem that is notorius for the 7g?
thanks in advance. zeth
cartel1_950
supra is gone
Jan 30, 2006
498
calgary
mkiii supra TT =1jz
1.5jz= 1jz block + 2jz head
and metal head gasket and arp studs help but isn't the cure all for a BHG
supradavenz
LOL HIES!
Apr 1, 2006
159
AUCKLAND, New Zealand
lawl, man theres alot of mixed up stuff right there...
mk3's came out with:
1jz-gte jza70 2.5L twin turbo running in parrallel
7m-ge ma70 3L non-turbo charged
7m-gte ma70 3L single turbo
1g-e ga70 2L non-turbo SOHC (i kid you not)
1g-ge ga70 2L non-turbo
1g-gte ga70 2L twin turbo running in parrallel
and a metal headgasket done right on a 7M would help prevent a BHG yes.
bighroder
Nov 15, 2007
11
Michigan
i dont plan on beating it to death, i just want a dd. All i can find is autos around here. another question, what did the 6 speed trannies come in? can I hook one to a 1jz? and how much $?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
cartel1_950 said:
mkiii supra TT =1jz
1.5jz=1jz head + 2jz block
do a search on the rest, trust me its been covered.
bighroder
Nov 15, 2007
11
Michigan
sorry im tryin to half ass do my history homework for school right know to,but thanks for the help I will just search it later.thanks again
cartel1_950
supra is gone
Jan 30, 2006
498
calgary
6spd tranny is 2jz and yeah turbo cars need premium gas. i ran 91 octane and the timing retarted a bit so i had to step it up to 92 octane and it seemed to help out
bighroder
Nov 15, 2007
11
Michigan
I just realy dont have time to look it up right now and I thought wiki was were anyone can just put on a thread. and its not always right.
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
A properly prepped block and head(machine work) along with a MHG and ARP head studs can do wonders for the BHG reputation on the 7M. But in any motor, a headgasket can fail.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
6 speed = V160
Came in MKIV Supra TTs
Yes it will bolt to a 1JZ, and 2JZ, but that's it. The bellhousing is actually part of the transmission, so you cannot swap on a different one. It's a little difficult to fit into the MKIII chassis. The transmission tunnel needs some slight hammering to get it to fit. I'm not 100% sure, but I think the shifter is not in the best spot, but it does work. There's a website somewhere on the internet where a guy documented how he put a V160 into a MKIII. Also, the V160 wants a 3.2 rear-end. Tallest you can find for a MKIII is a 3.73 (I heard rumors of an aussie 3.5 though, anyone have info on that?). so, yhe 6-speed gears will be really short in a MKIII.
There is also a 6-speed transmission for the 1G motor. I can't remember the tranny code, it's a J something I think. The transmission is out of a Toyota Altezza. Not sure how it would fit in a MKIII, but I bet it's clsoe.
Out of curiosity, what sort of class wants you researching Supras ;)
Ma70.Ent
1,871
NJ
If you have time to post a thread and/or wait for answer, then you have time to search...
