i was just thinking about going straight pipe from dp back as this is a weekend car wont get driven alot, i was looking at the cx racing dp with elbow.
if i get that with stock turbo, the clutch got replace around 20k ago, with 550's and a lex afm should i get something to control fuel (AFPR)?
Your car, but IMO, straight pipe on a mostly stock 7M is ricey as hell and obnoxious without the performance to back any of it up. It's one thing to be straight piped on a monster of a motor. It's an entirely different story on a stock car. DM carries a cat back for like $300.
550's and the Lex AFM are a waste with the stock CT26, IMO. I'd much rather have a larger trim CT with the stock AFM and injectors. That's how my 90 was and it was a ton of fun. The Lex AFM and 550's will run ok, but you should really have some means to tune with that and the AFPR alone isn't enough for my taste.
If I was you in your situation, considering the car runs well, I'd throw that money into suspension components. Everything on these cars is worn out. Get a solid platform to build off of, most suspension components are decently priced and you'd be able to get quite a bit done for the 1k depending. Once thats squared away, hopefully you'd be able to get some more money saved up that you can then put into performance upgrades, and your chassis will be ready for it.
Just my thought process.
Completely agreed here, but I'm gathering OP has more flashy plans than subtle (but completely worthwhile) suspension maintenance. :/
